More than 6 universes and 1:1 mapping
muscanto
Post by muscanto »
Could you please increase the universe count to 20 or higher? Even if I can only have 6 universes active at once, I would like to store universes from different venues that I travel to.
It would also be helpful if I could map one universe to a specific interface output instead of being force to put A on 1 and B on 2 for a 2-interface USB adapter. I'd like to be able to make A be universe 1 and B be universe 4 for example..
Re: More than 6 universes and 1:1 mapping
We already investigated the possibility of modifying the universe management system.
Unfortunately, we realized that this part of the software is very sensitive and critical internally. Even seemingly simple changes could introduce a significant risk of new bugs and would likely require us to go through a new beta testing phase.
For this reason, we currently prefer not to modify this system for now in order to preserve the overall stability of the software.
That said, we fully understand your use case and we appreciate the suggestion.
Return to “Editor - Fixtures”
