I would like to have an extra midi channel for each master fader to snap on a value like 100%
The value schould be changabele (maybe in the main properties where you assign the midi channel to your master fader...)
With this feature it's possible to use a master fader for dimmers of a fixture group and flash them at the same Time..
So you can run a Dimmer effect created in The Generator, Play it in live, put Master fader at 0% and Flash The Master fader by midi button to a higher value...
With this way you will see the effect running when you press the flash key...
I Hope some other users are with me
