no light beams from moving heads in 3d view [fixed]
global experience
Post by global experience »
Hey guys i have designed a 250w spot moving head fixture because my brand was't listed in the chauvet express 512 it works really fine and does everything it's listed to do but my problem is i can't seem to see anything in the 3d view so if i am to build a scene i need to connect all the lights so i could see them while building scene because they do not work in the 3d view, when i click pan and tint it works in the 3d view but when i try changing colors i get nothing at all....help is needed
Re: no light beams from moving heads in 3d view(chauvet express)
You can send us the personality file ; we will check it.
global experience
I am new to this whats your email address ?
In the channel "color", there must be levels like "open", "white", "red", ...
Then you will see the light beam in 3DView.
global experience
Re: no light beams from moving heads in 3d view [fixed]
Hey guys thanks...i got through....i even figured out how to get the gobo patterns to show in d3 mode also....thanks
