X-box DMX failure
usb to dmx (2003 - 2010)
bouyea
X-box DMX failure
Post by bouyea »
All the sudden my X-factor box has stopped recieving DMX commands from LIVE ... now LIVE editor/ LIVE live will not engage the dmx ..... controlboard shows that there is a X-factor connected but will not communicate to it .... I am running a Windows XP-home , on a dell inspiron 700m i have the most current version of Live..... HEEEEEELP!!!!!! have a gig on friday!!!!
Re: X-box DMX failure
May be your problem is: viewtopic.php?f=15&t=468
bouyea
Post by bouyea »
not a ground loop, live detects the box but will not talk to it and refuses to enter into dmx mode in the software
bouyea
Post by bouyea »
Update:
The dmx X-factor box runs DMX perfectly fine in stand alone mode, it is recognized by the software in the control board but the editor and live mode will not enter 3d or dmx mode!!!
Editor and Live same !
So this should be this:
viewtopic.php?f=11&t=1753
viewtopic.php?f=31&t=1752
bouyea
Post by bouyea »
okay, so whats the approprate USB "port" / "Permissions" do i need to open up or select????
-Thank you
This can not be fixed in our software.
You have to set your antivirus/firewall to not block communications for "Live", "Editor" and "ControlBoard".
bouyea
Post by bouyea »
Right, i know your software has no control over port settings but what ports does your SOFTWARE use so i can permission it
bouyea
Post by bouyea »
if it helps im NOT trying to use Live or Editor in network mode, its all over USB from a windows based OS (XP Home)
Return to “Box”
