Support,
I am so glad you incorporated this into the software. It works a treat and makes it so easy for me to tour and incorporate the houses fixtures into my preset programming.
Thanks!
DMX Output
DMX Output
"Who turned out all the lights?!?"
ashley.saylor@facebook.com
http://projectpinkband.com/
http://johnnywadband.com
Re: DMX Output
What are you using this for? I wasn't able to figure out how to use it effectively
Re: DMX Output
Sorry about the lengthy delay in replying. I was out of country for a two week tour and then I was in programming isolation to produce 300 mins of lighting programming for a gig last weekend.
Anyhow:
I use it like a patch panel. I have a standard house lighting program for theatre and festival lighting plots. I then assign my existing program to the patch list of the house or festival rig.
However when you use it, I patch the channel I want my programming to run but I also patch the channel to itself so I work and see it in the 3D imager SO if DSL Magenta is channel 36 and my programming is on channel 476, I patch the output of Universe 1 channel 476 to channel 36. Viola! I now have control of the house fixture on channel 36 of their dimmers. But as I said ch 476 only outputs to 36 at this point and I can't see 476 on my 3D imager. So I also output 476 to 476. And then I programme. If the venue has an address conflict, then I delete my 1 for 1 patch and work by observation of the rig. And my programming is 400 and above, and I have not yet had a conflict with a theatre rig or a 120K festival rig, with 13 Lekos, ACLS and Moles...
Anyhow:
