Master Fader option - from -100% to 0%
muscanto
Post by muscanto »
Can you add an option to reconfigure the faders to only be -100% to 0% and remove the +100% ? When pairing with MIDI control and fixtures were 0=255, I would rather have more travel distance from 0-127 with MIDI vs the ability to have +100% (which does nothing in my case).
Re: Fader option
We already investigated the possibility of changing the master fader course from -100% to 0%.
Unfortunately, we realized that this part of the software is very sensitive and critical internally. Even seemingly simple changes could introduce a significant risk of new bugs and would likely require us to go through a new beta testing phase.
For this reason, we currently prefer not to modify this system for now in order to preserve the overall stability of the software.
That said, we fully understand your use case and we appreciate the suggestion.
FYI, we chose, at the beginning, -100% to 0% for the master faders in the software V_II, and for the same reason we could not change them to -100% to +100%.
F.SEGUIN
Re: Master Fader option - from -100% to 0%
Post by F.SEGUIN »
non maintenant dans la version 2 on peut choisir entre -100% +100% et 0 -100% ce qui est super
A oui, c'est vrai.
Désolé pour cette erreur :-(
Après recherche, on avait implémenté les deux possibilités très tôt dans le code du logiciel V_II (en 2021), en proposant à l'époque uniquement l'option "-100% to 0%".
Et on a finalement rendu les deux options accessibles fin 2025. Ca a été très simple car toutes les évolutions du code de 2021 à fin 2025 ont tenu compte des deux options.
muscanto
Post by muscanto »
I would use the new version if there was a GUI option that laid it out more like V9. The changes are very disruptive to my workflow and I don't use touchscreens.
Return to “Live - Buttons”
