request - more than 10 light timelines [done]
LightningFM
Post by LightningFM »
Hello Support,
I have vague memories of this topic being been proposed in the past, but couldn't find it after some searches.
The TimeLine tool (which as you know I love) currently has a limit to 10 "light scenes timeline".
Scenario:
I'm programming some timelined songs (about 28) on a stage that has a set of five LED pars and twelve beam fixtures.
On some songs, I already used most (on some occasions all) of the 10 timelines "lines" available in the software.
The band recently bought eight new wash moving head fixtures and I want to program these into the timelines.
Issue:
There are not enough timelines lines available to do so efficiently for all tracks.
Request:
Please increase the number of timelines available in order to have more than 10 lines to work with.
Thanks!
I usually workaround this limitation by creating single scenes controlling multiple fixtures, but having an "Add Timeline line" button would be better:
- to the look of the show
- to simplify the programming work (a lot!)
Pauluzzz
Re: Request: more than 10 Light TimeLines
Post by Pauluzzz »
+1
Adds flexibility, I use the timelines to build the color, pattern, movement / strobe. If I would have stored this information into a separate scene each time, i would have ended up with hundred of files for each different combination. However, there are only 10, so this flexibility has its limitation and if not to complex, more timelines would be of great help.
Done in the fix file (V9.2.19).
LightningFM
Re: request - more than 10 light timelines [done]
Works great! Thank you :)
Pauluzzz
Post by Pauluzzz »
Great, works like a charm, with 20 lines I have more than enough for now. Thanks!
Return to “Live - TimeLine”
