request - option to disable unasigned pages
muscanto
Post by muscanto »
Support-
Can you add an option to the program that can be enabled so that if a page is not selected on a board in Live, it is disabled?
I'd like to create 3 different boards and only select one during a show depending on the show but have the buttons assigned to the same MIDI control.
It seems that keyboard and midi triggers continue to trigger buttons and macros when a page is not assigned to a board.
Luc Henrion
Re: Reqeust - Option to disable unasigned pages
Post by Luc Henrion »
Good idea !
+1
Re: Request - Option to disable unasigned pages
This may be possible to do.
Noted.
Bob_be
Post by Bob_be »
+1 (as a [preference option to turn on or off)
tcld
Post by tcld »
+1
andyfoxall
Post by andyfoxall »
+1 (could be an option in button settings for each button, or universal)
Pink LD
Post by Pink LD »
This is a functionally similar long time request that keyboard/midi triggers be page dependent.
Matt26
Post by Matt26 »
+1 for sure. This would also solvate problem I have been having where time-triggered buttons active regardless of whether or not you want them to in every situation. If the time-trigger of the buttons where to become disabled if they were on an inactive page, that would be great.
This will be possible to fix your problem with new major software version.
Regarding dates, not easy to plan something as long as pandemic situation blocks all possibilities for us for tests in real lighting stages.
Return to “Live - Buttons”
