BPM to Generator
seantosz
BPM to Generator
Post by seantosz »
I am seeing the new DMX program sound switch and the dimmer pulse on the beat is very attractive. Is there any way to simulate this in showXpress? I can get the effect in the generator with a straight line dimmer but cannot pulse the generator run time to any bpm somehow? Just making a speed slider in live and trying to get it close kinda works but not really.
Here is the effect in one of their videos. https://youtu.be/XR_jLU2wUGE
Re: Generator to BPM?
Generator scenes are complexes scenes with different curves for each channel, and with fan between fixtures.
Who do not see how it could be possible to trigger something in such scene via BPM.
The Steps scenes can work with BPM, because they are made of basic steps, and it is easy to forward steps with BPM.
seantosz
Re: BPM to Generator
Post by seantosz »
I understand generator is more complex and operates at a higher frequency rate of change. However there is also a repeat time in the parameters to adjust when you set up the generator. In live mode you can adjust this somewhat with a speed slider. So why not at least a BPM slider or have it calculate the repeat time based on the manual/auto bpm present ?
For example: 120 bpm is 60 s / 120 = 0.5s so why can't you set the Generator to 0.5s Could even set whole note, half note, quarter note settings?
[request] BPM to generator repeat time
thanks
This is still obscure for us.
Please send a real example.
Create a lightshow with 8 moving heads for instance.
Create a Generator scene with:
- for pan/tilt channels - circle curve - fan = 10% - duration = 20s
- for color channel - one color chasing - fan = 25% - duration = 3s
- iris channel - sinus curve - fan = 0% - duration = 8s
And then tell us how you wish to forward in it with the BPM.
seantosz
Post by seantosz »
I understand better what you mean now. My original interest was only to get a pulsing dimmer line similar to that in the sound switch demos that I have seen. So I was talking about only one channel.
But to have a multiple channel generator program a BPM sync would lock everything into multiples or divisions of the BPM. This would even be better and enhance a more musical lighting performance. Also possibly with division or multiples of the BPM such that it would make sense to the function of each channel. For instance I would not want a pan/tilt to be repeating to the quarter note of a typical pop song (90-120 bpm) but I might want the dimmer to.
Following your example a BPM lock (or sync in other words) for 120 BPM would be something like.....
- for pan/tilt channels - circle curve - fan = 10% - duration = 4s (15bpm, 2 whole notes in 4/4 time, 2 measure repeat)
- for color channel - one color chasing - fan = 25% - duration = .5s (120bpm, quarter notes in 4/4 time, every beat)
- iris channel - sinus curve - fan = 0% - duration = 1s (60bpm, half notes in 4/4 time, half a measure)
The fan % would still work the same way.
The period calculation is simple enough. Ver 8 only gives integer input options for the period input of the generators. More decimals places (bit length) would be needed to accommodate a more accurate time divisions for a BPM sync. My example worked out easily but say change that to 119bpm and you would need 0.504 seconds per beat. Ideally you would only be programming the coefficients in the generator periods and then the BPM in live menu will determine the actual timing that are needed so they line up with the tempo.
seantosz
Post by seantosz »
Does this make sense?
I was using the word period instead of duration in certain places.
Thank you for the explaination.
Whatever is the decimal place, a drift for the calculation of the durations will arrive. Sometimes after 2 loops, and sometimes after 100 loops, but it will arrive.
So we are indeed not warm to enter in such problematic.
Sorry for that.
seantosz
Post by seantosz »
I would accept the drift over the lack of this functionality. The stepped scenes also drift. A 32bit word could handle 7 decimals places.
ok good luck
thorehl
Post by thorehl »
seantosz wrote:I am seeing the new DMX program sound switch and the dimmer pulse on the beat is very attractive. Is there any way to simulate this in showXpress?
seantosz: Instead of using Generator to make a dimmer pulse, create everything you need in Generator apart from dimming. Then create a Steps-file with your dimmer channel, and activate it a all using a macro button.
Thore
Controller: 2x Akai APC mini
my DIY light mixer
seantosz
Post by seantosz »
I thought of that but it seems you can only sync steps scene to the exact BPM or quarter notes? So setting a full on dimmer on one step and full off dimmer on the second step with the fade selected will only give a dimmer pulse of a half the BPM. I am at least trying to get quarter notes. I was looking for the generator to sync and repeat to the bpm so that you can utilize the more precise curves to program performances that can sync to the eighth note and off beats without programming a static sequence in timeline.
Thanks for your input I will try to do something like what you are saying.
Return to “Editor - Generator”
