Hey support,
I've been trying out V9 a bit and I have noticed some weird performance issue.
When having the software open while having a youtube video on a different screen, whenever I do something I can see the video hang for a split second before returing to where it's supposed to be.
I opened up taskmanager to see if the system was taxed but the max on the cpu was at max 50%, RAM was at about 7 GB (of 16) was used so that isn't the issue either.
Please take a look at this, I might be able to make a video if that would help.
Greets,
Bart
V9 - Weird performance issue
Re: Weird performance issue
So, I've installed V9 on the club pc. Everything is working with no stability issues so far (will be running it tonight with a backup pc).
Two more issues I've run into:
1. On BPM I found that sometimes the lights skip a step, so they stay on the step they are on for 2 beats instead of 1.
2. In the editor I can't easily ajust the individual step time. If I click the time of a step I have to delete the numbers from right to left before filling in the new value, this is really annoying but since it's an alpha version I get that. The main issue is that editing the step time does something really weird. It doesn't seem to actually ajust that step but all steps, although the visible time on the other steps stays the same.
Edit: Never mind the underlined part.
Please look into this.
