One of the most useful features added to this program is the release all buttons option.
This feature makes setting up macro buttons much easier. I also use it to return to "home" positions in a live busking session.
However, the buttons chosen as exceptions do not hold memory when the program quits.
The exceptions must be re-activated manually each time that show is loaded. This is inconvenient.
A fix for this would be appreciated.
A release all exception would be nice as a window option. Maybe added to the window menu pulldown (right click)
This exception would cover an entire window, not just 1 button at a time.
A solo feature would also be a nice addition to this program.
This feature can be found on larger lighting consoles like Grand MA and Hog 4.
The solo feature would be a fixture group direct control.
It should be able to be pre-programmed by the user as a type of sequential step list with each step being an individual fixture within the group.
Each step can be programmed to activate a fixture so it may be focused (shutter>open Dimmer>Full ect) as if it were a step in a chase.
As a group of fixtures is selected for "solo" the 1st fixture in that group will be lit for focusing, while the others remain dark.
A "go" or advance button will be needed to toggle through the remaining fixtures in that group lighting 1 at a time.
Control of this function would be helpful trough the remote app as focusing is done from the stage.
This would be a very useful feature for someone who uses the same equipment for each event, but in different venues and locations.
Thank you.
"Release all" exception per window Add Solo Button?
Re: RELEASE ALL exception per window Add Solo Button?
+1 to all these ideas
