Problem creating objetcs using 3DMAX+SketchUp
zkflow
Post by zkflow »
Well... i suposed only to have something a podium rect but... what i'm doing wrong?!!??
i'm talking about the black space inside the obj....
Lighter007
Re: Problem creating objetcs using 3DMAX+SketchUp
Post by Lighter007 »
You created this object with SketchUp, didn't you? Try moving the object in SketchUp to where the axes cross so it's near the red/green/blue lines.
Export it again and it should work.
Greetings from Germany! :)
zkflow
Post by zkflow »
Lighter007 wrote:You created this object with SketchUp, didn't you? Try moving the object in SketchUp to where the axes cross so it's near the red/green/blue lines.
It works correctly!!! Now... i want to create some objects without uson Sketchup as a converter. Only render directly from 3DMAX but i have problems.... i can change the size in the parameters Y and Z... but X locks in "0"...
Return to “3DView”
