TheLightingController 9.4.7 not found (intel)
Posted: 20 June 2026, 15:48
by juniordbbj
Hi everyone, I'm using the D512 interface on an Intel MacBook Pro with Big Sur installed. It always worked until I installed thelightingcontroller classic 9.4.7 for Quick DMX. The interface is connected correctly to the computer; the system log shows it without any problems, and the interface works correctly on another M3 MacBook I have, using the same cable. The startup panel says 0 interfaces found, USB library not avallable.
Re: TheLightingController 9.4.7 not found (intel)
Posted: 22 June 2026, 06:58
The software working on your M3 is the arm version or the intel version of our software ?
If it is the arm version, could you please try the intel version on your M3 ?
