MIDI out CC for master faders doesn't work
Posted: 19 April 2025, 20:16
by muscanto
I am trying to record master fader data via MIDI CC from showxpress to ableton and I cannot get it to work. If I manually create a midi clip with CC data and use the learn function, I can show that data is passing through the computer from ableton to showxpress in the IAC MIDI driver. I'm on the latest version.
I have both the input and output configured in showxpress for the midi device with the correct device ID as well as the device enabled for input and output in ableton both on the track and in the session preferences.
Could this be a bug?
Re: MIDI out CC for master faders doesn't work
Posted: 20 April 2025, 17:03
Do you see the midi message in the window "Midi logger" of our software ?
Posted: 20 April 2025, 17:06
by muscanto
I will take a look today and report back here.
