the window "Object settings" is not visible [fixed]
Posted: 16 December 2017, 17:15
by will_notley
hello
the objects setting window is not show
operating system : windows 10
software: sweet lights.
[image]
Re: 3d viewer
Posted: 17 December 2017, 18:51
It might be outside of your screen resolution (may be you changed monitors ?).
Please try this:
- close the window 3DView
- open the file "../YourLightshow/3DView/3dview.ini" with a notepad application
- delete the line starting with "Frm_ObjectsSettings ="
- save the file and close it
This will reset the location of the window "Object settings". Then you should be able to see it again.
Re: the window "Object settings" is not visible
Posted: 18 December 2017, 16:28
by will_notley
hello
thanks
