Import button greyed out [fixed]
Posted: 24 August 2016, 22:51
by Alan_G13
Hi
Using the Export Lightshow option works as expected, but copying the exported lightshow directory to a flash stick and then trying to import it (Import Lightshow) isn't possible as the Import Button on the Import Lightshow window is greyed out ?
This only seems to happen for this one particular lightshow. I've checked the contents of the folder which doesn't work which seems to have exactly the same structure and same directories as ones that work OK. If I manually copy and paste the directory (the one that won't import) into the LightShow directory and then use Open Lightshow, it opens fine - it's just not available to Import ?
Cheers
Alan
Re: Import button greyed out
Posted: 25 August 2016, 08:20
Please send this lightshow (viewtopic.php?f=3&t=168).
We will check it.
Posted: 25 August 2016, 09:56
by Niffo
FYI : The "Import" button stay grayed if the lightshow folder does not contain a "scenes" directory
Posted: 25 August 2016, 10:08
by Alan_G13
Hi
The lightshow folder definitely contains a Scenes directory. I've emailed the lightshow to support so they can take a look at it
Posted: 25 August 2016, 14:24
"scenes" and not "Scenes"
Please do not change the name of the folders made by the software.
