Intimidator Spot Duo
Posted: 08 August 2014, 14:32
by ScaryGary
I'm not able to view both heads in the 3D view. It shows as a fixture with a single moving head, which would be okay in 10 channel mode, but in 20 channel mode both heads are controlled independently of each other.
Re: Intimidator Spot Duo
Posted: 09 August 2014, 21:33
by Lighter007
(Comment removed)
Posted: 10 August 2014, 08:44
You have to declare two fixtures at two different dmx addresses, and the commun channels could work only with one head.
Posted: 12 August 2014, 16:47
by ScaryGary
That doesn't give me the ability to see each of the heads working in the software, though. I thought about making them 2 different fixtures, but the controls for one head use every other channel. So I could add 2 lights in the 3D view, but not control them as 2 lights, so it would be pointless. Is it possible we'll see a proper 3D profile for them?
Posted: 12 August 2014, 17:29
by JohnRichards
@ScaryGary
What I have done to have a perfect 3-D view is to use the actual profile and set it to not being seen in 3D.
I then create how ever many profiles of each light with how many channels each light uses with high dmx values.
I then do a dmx output patch sending each channel to itself (to handle actual fixture) and to corresponding dmx addresses of the 3D fixture. An example would be Chauvet 4 Bar Flex setup as :-
Dmx 1-15 Mode,Dimmer,Strobe,R1,G1,B1,R2,G2,B2,R3,G3,B3,R4,G4,B4
3D Led1 Dmx 301-306 Mode,Dimmer,Strobe,Red,Green,Blue and Led2 Dmx 307-312, Led3 Dmx 313-318, Led4 319-324
My Dmx Output patch would be, 1 to 1+301+307+313+319 : 2 to 2+302+308+314+320 and so on
Hope this helps
John
