Snapping to Audio Points
Posted: 30 June 2014, 11:19
by Lighter007
Can you add a function to remove the "Light-scene-snapping" to the audio points when a Track is existing?
It may be a good idea but for fast light scene changing it´s defenetly to unprecise.
Lighter007
Re: Snapping to Audio Points
Posted: 30 June 2014, 14:02
Can you please explain the "Light-scene-snapping" ?
Posted: 30 June 2014, 18:43
by Lighter007
OK after some testing I came to this:
This problem has nothing to do with audio snapping, it was a false interpretation of my.
The problem occurs when I want to lay multiple scenes about each other because then I cannot place them as precise as when I set them alone in a Timeline.
EDIT: It does not always happen!
so you may not able to reproduce it.
Now everything works fine.
