preset > left click does not change values [fixed]
Posted: 23 April 2012, 06:44
by TwoSound
When I add the 'preset button' function to a show in the live mode it only works correct when clicking and towing the preset to 1-2-3 for example. When I click on preset 1-2-3 the fader moves to this position but the software doesn't act like it. When i tow the fader button is does works. Can this problem be solved? I use this for light dimming settings. Thank you!
Re: Error preset button in live mode
Posted: 23 April 2012, 08:08
We do not really understand the explained problem.
But, we just checked (Windows), and it works as expected.
Posted: 23 April 2012, 09:47
by TwoSound
When you select de button in the fader and tow it, it works as it should but when you press one or more stepps further then the button in the fader stand, then the button jumps to its new position but the fixture doesn't respond on this action. Only when i tow the button to the new position it responds. It's hard to explain in text but i hope you can understand it this way?
Posted: 23 April 2012, 10:29
Understood.
This problem is fixed (only in beta version for now).
Re: preset > left click does not change values [fixed]
Posted: 23 April 2012, 10:35
by TwoSound
Perfect! I'm looking forward to the next update :-)
Posted: 16 May 2012, 10:58
by Niffo
You can also try the beta version ...
