Controlboard malfunction [fixed]
Posted: 03 March 2012, 06:15
by rbekel
I have 2 different sets of 4 fixtures. Each of the 8 fixtures have a unique DMX address. I have a page set up with each group turning on various colors. Each separately work well. But when I turn on a color with one group, and then turn on the same color with the second group; the second one will turn off the first group. What is going on? It happened on a show I had way back from version 5 and was converted to version 6. So I created a whole new show and now it's doing the same thing? Is there a maximum number of buttons that you can put on a page? I think in this case both pages has 15 buttons on them. I then set up a new page using macros to turn both groups on a certain color. The same thing happens when I try using the macro button say to turn both groups in Red or Blue or Green. Can you tell me what is happening?
Re: Controlboard malfunction
Posted: 03 March 2012, 06:21
by marco
It has to be aktive and non aktive channels
Watch
viewtopic.php?f=31&t=383
And
viewtopic.php?f=11&t=637
Posted: 03 March 2012, 07:05
by rbekel
In my above senerio both sets of lights are RGB LED Pars. Flat Par Tri7X ,and MegaPar Profiles. Both lights use the same exact dmx settings for all 7 channels. so your saying that if a channel is totally off or at the Zero position that it should be low lighted and not be green?
Posted: 03 March 2012, 07:41
by rbekel
I went back and lo lighted the non used or inactive channels and that seemed to have fixed the problem. Thanks for the fix!!! When is a new user's manual coming out for the software??? :D
