able/disable channels
Posted: 05 October 2011, 12:36
by greghy
is there a way to able or disable some DMX channels using a button?
Thanks,
Greg
Re: able/disable channels
Posted: 05 October 2011, 16:47
by Pink LD
Sure, why not? Make a scene with the faders you want deactivated and make a button with that scene. I could see a number of ways you could use that. That gives me a number of new ideas... =)
Posted: 05 October 2011, 17:04
by greghy
The problem is that: I'm working for an installation in a pub with different rooms (to be switched on separately).
I've made some color-theme scenes that change the colors to all the PARs (in all rooms) simultaneously.
I've a LED PAR that doesn't have a dimmer channel. So I want to switch it on or off.
I've tried creating a scene with the RGB faders to 0, but after activated that scene if I change to another color-theme scene the fixture switches on.
Sorry for my bad english,
Greg
Posted: 06 October 2011, 04:21
by marco
Hi
This is possible when u program the rooms separate. If u have 2rooms make 2pages with the seperate scènes,then create a 3rd page with the combined scènes, u can use the macro funtion to combine excisting scènes.
Posted: 06 October 2011, 05:07
by Pink LD
Marco beat me to the punch. Thanks Marco!
Posted: 06 October 2011, 05:34
by greghy
Ok, but how can I select which room switch on and what color-teme scene use in all rooms, using macros?
If I make a macro that change the color theme to all rooms simultaneosly, I can't choose which room switch on.
Thanks,
Greg
Posted: 06 October 2011, 11:24
by tomrbland
Does this solve your problem? I have done it for two cases, one where your fixture has a shutter channel and one where it doesn't.
Posted: 06 October 2011, 12:45
by greghy
tomrbland wrote:Does this solve your problem?
No, because in this example I can't switch on the fixtures with no shutters using a button: if I press the "Red" macro button, automatically these fixtures start to illuminate.
I want to control with a scene the color-theme and with another scene the on/off.
Thanks to the example!
Greg
Posted: 06 October 2011, 21:20
by tomrbland
If you want individual rooms on then you use the individual pages for room 1 and room 2, if you want them both the same then just use the macros.
This is the problem with having fixtures that don't have a shutter channel. As you can see if your fixtures have a dimmer/shutter channel then it works.
Alternatively wire the par cans up to a switch pack, they have on off switch then! (joking!)
Sorry that I can't make the software work exactly how you would like.
