Page 4 of 4
Re: request - global Offset [done]
Posted: 27 June 2019, 17:40
by DeeStage
Failure by starting a generator screne with Pan offset.
Pan offset of both fixtures is +10780
Fixture 2 in the generator project has a Pan reverse to get an symmetrical view.
Problem: Fixture two with pan reverse starty the generator project shomewhere over the edge.
Vid:
https://youtu.be/BtSiwGtZCsQ
Hope you can help
It looks really creppy in live because the second fixture is turning around some seconds before it starts with the real movement.
Vid:
https://youtu.be/ZNGMJOW93bI
Posted: 08 July 2019, 19:10
by DeeStage
any ideas to solve this problem ?
Posted: 09 July 2019, 05:39
by Niffo
Pan/Tilt offset is only affecting final DMX output, and does not have any impact on Generator curves.
What you are experiencing in Generator seems to be the side effect of a negative "shift" in the curve parameters.
