Version 9.4.1 does not receive MIDI In [fixed]
Re: Version 9.4.1 does not receive MIDI In
To understand the problem, we need to reproduce it, and we're looking for the simplest way to do so.
Could you please try sending MIDI messages using "VirtualMidiSend," which is available for free on the App Store?
In the meantime, to try to get the D1024W interface working from v9.3.8, you can try putting the "efk_hardware.dylib" file from v9.4.1 into v9.3.8 directory (not tested)
mrchacha100
Post by mrchacha100 »
Hello...thank you for the speedy response.
After checking with your midi software and also ours, we have found that the software is not receiving PROGRAM CHANGE Midi signals.
The software you suggested sent Note on and this worked. We changed to note on midi from qlab and other software and Lighting Controller received the data. All our midi messages are Program changes and these are still not received, so this doesn't solve the issue but I hope you will be able to recreate the error now using Program changes and find out why the software is not accepting them in this version.
Thanks again for your help!
Thank you for the clear report!
Problem only reproduced with QLab, which sends "Program Change" messages without a Data2 value at all.
The issue did not exist before version 9.3.21, when the macOS software did not handle multiple MIDI messages simultaneously.
Fixed for the next fix file.
The new macOS (intel and arm) software version which fixes this problem is available here: https://forum.thelightingcontroller.com ... .php?t=114
juankasuarez
Re: Version 9.4.1 does not receive MIDI In [fixed]
Post by juankasuarez »
Just test it and midi works!! thanks a lot for the help.
Good news !
Thank you for the feedback.
