Page 3 of 3
Re: window 7 64bit
Posted: 02 November 2010, 14:28
by lynroys
i have installed 6.25 with the fix and the drivers
the dmx still seems to be flickering flashing and stepping
any ideas?
Re: window 7 64bit
Posted: 02 November 2010, 14:58
by lynroys
Help Pleasee
the problem seems to be on the controlboard its self aswel
when you move the mouse over the controlboard icons the
picture in the middle keeps stalling just like the dmx is doing
when i unplug the usb and plug it back in again, in device manager it says
this device cannot start. (code 10)
i have to disable the device then enable it to get it the start the device properly
dont mind if anyone wants to remote desktop to have a look
would like to get this new system up and running then i can use it to gig with
thanks in advance
Re: window 7 64bit
Posted: 02 November 2010, 17:35
May be you have a "ground loop" problem (?)
Please read this: viewtopic.php?f=15&t=468
Re: window 7 64bit
Posted: 03 November 2010, 12:15
by lynroys
i dont know because it works totally fine on the computer next to it plugged into the same socket (vista 32bit)
anyway i have ordered a
Chauvet DATA Stream 4 DMX-512 Optical Splitter
is there anything else you can think of that it could be?
NEW UPDATE
i have done some tests myself this is what i have found .....
this is all with no dmx cable connected
in device manager if i unplug the usb then plug it back in sometimes
it comes up with a yellow triangle saying "could not start device"
with no box connected and i set up a simple slow fade and watch the dmx channels it works fine
if i do the same with the box connected the slow fade is jumping .....
  • no dmx cable connected
Re: window 7 64bit
Posted: 03 November 2010, 14:16
by lynroys
:D :D PROBLEM FIXED :D :D
picked up a (pci usb card) on the off chance it was a motherboard usb problem
and my flickering and jumping problem has gone
thank you to all who has tried to help me ... it is apreciated
support mother board is a asrock N68C-S if you can get to the bottem of the problem
Cheers
Simon & thanks again :D
Re: window 7 64bit
Posted: 03 November 2010, 15:35
Thank you for this explaination.
