DMX 400 or so [fixed]
Re: DMX 400 or so
"accu sopt#4" is addressed in second dmx universe. If you select "Universe 2" in Setup, you will see it in the "dmx addressing" tab (of course the nb of universes in ControlBoard->Setting must be more than one).
Here is your dmx addressing file without "accu sopt#4".
Important:
We recently found 2 bugs in Setup, which might be the cause of your corrupted dmx addressing file.
The fix is here: http://download.thelightingcontroller.c ... ware/beta/
- firstly, you have to install the beta version
- then you have to paste the fixed files "fix_for_Windows.zip"
tomrbland
Re: DMX 400 or so
Post by tomrbland »
Have you tried getting rid of it in fixtures.ini (For XP - C:\Documents and Settings\**USERNAME**\TheLightingController\LightShows\Pictures\3DView\fixtures.ini)
tomrbland
Re: DMX 400 or so
Post by tomrbland »
Sorry support didn't spot your post on the next page!
directsound
Re: DMX 400 or so
Post by directsound »
Ok thanks I totly forgot I tryied a second univerce and I didnt know it would show in the first room as I didnt play with it enough ...as for the fix file If I just download the new 6.23 file dose that have the fix in it ?
thanks for getting back on track
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
http://www.directsound.com
Re: DMX 400 or so
No, V6.23 is too old.
- you have to install the current beta version (V6.24beta)
directsound
Re: DMX 400 or so
OK THANKS i GUESS i a bit behind on my updates...thanks for the great work staying on top of it all...Just let me know if there is anything I can do to help you move closer to your objectives
thanks
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
